Llandow circuit map
- Maver-Nick
- First Name: Nick
Llandow circuit map
Phil... any chance you can post up that aerial view and google map of the circuit that you posted up last year... pleeeeeeease...
- speedy(delboy)
- speedy(delboy)
Little Loris
- speedy(delboy)
That point is the start line, then once started it is part of the circuit, so your down to around 30 - 40mph in there, its called The Bus Stop and as you can see is a left, right, right, left. However, don't worry to much, because if for some reason you are carrying to much speed to get in there, then you can use the Run Off which is straight ahead.Little Loris wrote:I've just done a poo
Are we going around clockwise? Also, do we get to do the little kink north-east of the circuit or does it go straight into the right hander?
- speedy(delboy)
Gsxrage wrote:Thanks Phil I needed to learn which way to go !!!!!!!!!!
err....... along the straightish bit, turn right. Turn right again, along the straightish bit, and repeat, etc., etc.,
- speedy(delboy)
speedy(delboy) wrote:You just keep out of my FFFFFcuking way this year you tartGsxrage wrote:Thanks Phil I needed to learn which way to go !!!!!!!!!!
hey we did keep out of your way !!!!!!!!!!!!!! if you remember we both passed you before you went off
PS3 name lesnage
PS3 name lesnage
I think the scariest part and most challenging is where you fly down that back straight (bottom of pic) try and keep it straight through the chicaine and then just drop the bike in hard for the right hander. Just turn the bars to the left (counter steer) as hard as and just pray
As your carrying so much speed down there
My butt squeezes and grips the seat everytime there. Love it
- speedy(delboy)
Blimey wrote:I think the scariest part and most challenging is where you fly down that back straight (bottom of pic) try and keep it straight through the chicaine and then just drop the bike in hard for the right hander. Just turn the bars to the left (counter steer) as hard as and just prayAs your carrying so much speed down there
Ya need to relax mate as being tense is the worst thing you can do !
PS3 name lesnage
PS3 name lesnage
