gsxr 400
kicker2508
First Name: tom
gsxr 400
Post by kicker2508 »
Has anyone had a previos experiences with them any problems with them or common faults I should look out for.
Tom
Bikes i've owned: mobeltte----->ts50------->gs400------> r6 ------->bandit 400 --------> cb250--------> kx125
Bikes i own: dt 125 field bike ------ gsxr 750
Re: gsxr 400
The carbs. Everyone seems to have problems with them.
kicker2508
First Name: tom
Re: gsxr 400
Funky wrote:The carbs. Everyone seems to have problems with them.
A simple fix like clean them out or abit more complicated
Tom
Varcon
First Name: Edd
Re: gsxr 400
Post by Varcon »
Carbs usually require a new set of o rings to get them working right again - fairly easy job to do and you can get the rings for £11.
Other problems are usually just general old bike problems!
jam
Re: gsxr 400
Post by jam »
34mm CV carbs from a GPZ900R will fit on a 400GSXR/Bandit motor, and are a far better carb, or 30mmCV carbs from a ZRX400 will also fit and are a better carb but harder to find. spacings should be 77-85-77 same as XJR12 ZRX11 but they use 36mm CV and won't fit into the rubbers. I may have a set of 30mm ZRX400 carbs kicking around if you need them.
ZXR400Lee
Re: gsxr 400
Post by ZXR400Lee »
My buddy has a GSXR400.. he had awful carb problems..
Positive side.. GSXR750 brakes fitted on the front without modification! :D
kicker2508
First Name: tom
Re: gsxr 400
cheers for the info jam . Hmm the carbs sound like a nusience :( Well im off to see the bike today I will ask if he has had any problems with the carbs hopefully not.
Tom
Re: gsxr 400
get him to start it up, warm up for a while. If you can definitely have a test ride.
kicker2508
First Name: tom
Re: gsxr 400
Bike didnt even start :(
Took plugs out checked wiring was sparking but not very well what would fix it as its a nice bike in the lucky spirt colours. Would like it but at £750 and not starting i though i would leave it and ask in here to see what you would sergest may be the problem.
Tom
jam
Re: gsxr 400
Post by jam »
It ain't worth £750 if it doesn't start, it's worth no more than a couple of hundred quid, dpending on which model it is, if it is a GK76 slingshot then that is better than a GK71 beam frame, or a GK73 slabby. if it's a GK71 stay away from it, and only go for a GK73 if it is in excellent condition, which it sounds like it isn't. So unless you get it for peanuts walk away.
kicker2508
First Name: tom
Re: gsxr 400
Yeah I think I will walk a
way from this one.It was the GK76. I wasnt impressed it didnt start as he said it did. He said he guaranteed the engine was sound but i didnt want to spend £750 of my money if the engine was shot and he didnt know how the gearbox was plus i've heard they drop vavles aswell.
Tom
Re: gsxr 400
If you've got £750 to spend, my 400 Bandit is up for sale at that price :D And it runs really nicely :wink: !
Re: gsxr 400
Sounds like you dodged a bullet there. If you're after a 400, Badgers 400 is worth checking out.
Banditmax
Re: gsxr 400
Post by Banditmax »
jam wrote:34mm CV carbs from a GPZ900R will fit on a 400GSXR/Bandit motor, and are a far better carb, or 30mmCV carbs from a ZRX400 will also fit and are a better carb but harder to find. spacings should be 77-85-77 same as XJR12 ZRX11 but they use 36mm CV and won't fit into the rubbers. I may have a set of 30mm ZRX400 carbs kicking around if you need them.
Are the GPZ900 ones exactly the same spacing as the bandit ones? I guess the airbox won't fit with the 34mm ones?
jam
Re: gsxr 400
Post by jam »
Yes they are the same at 77-85-77 centres. you may find the GSXR slabside rubber will work
