Sunday 21st June
Look in here for local ride outs...
bambam
First Name: Jon
Re: Sunday 21st June
Post by bambam »
Won’t be making this as have house stuff to do.
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
In light of Juggs post at top of page 6 I invited Dave to tag along with the first group bearing in mind Phil (Robbo) said he's only doing part of the ride. That still stands but perhaps Nick and his friend could, as suggested, do the third group setting off at 09.30 so Juggs and Claire can still tag along with some of the gang as we sail through Chard. That leaves Dave open to either group. As it stands I'm expecting him to leave at 9.00 with me....his call. I'm sure all will be clear in the morning =:)
at least something will be :)): :)):
DaveH
Post by DaveH »
Aye. It’s a bit like herding cats this isn’t it ... and into groups of six at that LOL!
Kata
First Name: John
Post by Kata »
Was in a group of 12 or so last night and went past the police at least 3 times without being stopped and invited to discuss social distancing.
bkingalan
First Name: Alan
Post by bkingalan »
If they do a reg check none of us are local to each other so that will confuse them and we can deny all knowledge of each other 😜😜😜😜
MV 800rr brutale
MV 800 turismo veloce luso
Jug
First Name: Rich
Post by Jug »
So....is there a 3rd group or not??
Kata
First Name: John
Post by Kata »
TLS-Moose wrote: Jun 16th, '20, 14:54
Jug_Inspector wrote: Jun 16th, '20, 12:44 Try this link.
https://app.box.com/s/w286kilmpnr0ntcxjh86qskaqfisryq6
That should be a small .itn file that you place in the itinerary folder on your TomTom.
Then when you open the software that "route" should be available to select as an itinerary, just select it and it should then calculate the route, if so check it carefully to make sure it has gone off track.
Are you deliberately sending him elsewhere :-? :shock: =))
Hi Jugs,
I tried uploading it into the TomTom MyDrive website but it seems to require a GPX file (I thought that was a kawasaki). However, I'll try just dumping in to the tomtom directly as you say.
Jug
First Name: Rich
Post by Jug »
Try the link I did for Dave as that is a gpx file and will probably work better.
Kata
First Name: John
Post by Kata »
Kata wrote: Jun 20th, '20, 19:37
Hi Jugs,
Just copied the itn file direct to the tom tom. INstalls a rout called sunday 21st June TomTom (2) and it just shows the initial location at Tiverton, not any stops or route...
Kata
First Name: John
Post by Kata »
Jug_Inspector wrote: Jun 20th, '20, 19:49 Try the link I did for Dave as that is a gpx file and will probably work better.
Yep that works.
Well actually I imported it but just keeps the start and end points. TomTom software is utter pants. I ended up grabbing the coords listed for the points and just entering them. Thanks for giving it a go though.
Red5
Post by Red5 »
Hmm, glad I rode it this afternoon... Route works with bullet point guide and destinations with these new inventions called road signs.. They're frikkin excellent. They tell you what the road number is and where it's going and it means you're looking and observing what's around you rather than looking at a screen in way of your vision... Just saying :-bd \m/ =))
Kata
First Name: John
Post by Kata »
There's no way I want to get lost down there and end up "squealing like a pig" to a soundtrack of a Banjo or two.
menzies3032
First Name: Robert
Post by menzies3032 »
Looking forward to it will be there for 9:15 start see you in the morning
ptolemyx
Guest user
First Name: Brian
Post by ptolemyx »
Rain has stopped, sun is out, sky is blue :-bd
