Page 3 of 6
Posted: Dec 5th, '05, 16:44
by andrew
georgie_d wrote:well i have a problem, i went to warm the bike up make sure the bats not flat b4 the rideout, started it with the choke on dropped the choke about half way blipped the throttle and then bang!!!! now i cant get the thing to turn over :cry:
this might sound like a silly question but what kind of bang was it. Reading that it sounds like you just had a backfire from unburnt fuel in the exhaust., which may or maynot be related to it not starting.
Unless your saying the engine went bang not the exhaust????
Posted: Dec 5th, '05, 17:19
by Tom
Andrew I asked that question the in the other thread, I cant remember the answer :lol:
But it sounds very similar to when my regulator/rectifier went.
Because something is draining the system when you press the starter.....actually, is the rectifier wires ok?
And when bump starting, it really helps having someone to keep pushing as the momentom of the bike keeps up.......if that makes sense!
Posted: Dec 5th, '05, 18:41
by georgie_d
yeah it was backfire which i get all the time anyway but it just so happens it backfired and then immidiatly cut out
Posted: Dec 5th, '05, 18:42
by georgie_d
Tom wrote:Andrew I asked that question the in the other thread, I cant remember the answer :lol:
i did check the rectifier cables and nothing was burnt out but like you say it could be thhat then :?
Posted: Dec 5th, '05, 21:17
by Tom
do you know anyone with an R6 that you can borrow there rectifier?
I nicked dodgys to check if mine was faulty, so you then dont end up buying parts for no reason.
Posted: Dec 6th, '05, 10:08
by andrew
a rectifier is a very easy part to test.
You need to get a multimeter put it on the Ohms (resistance) setting and you should find one way it has a high resistance and the other way it has a low resistance - the rectifier is just a diode.
I have a multimeter if u want mate - could also use this to check all the fuses.
What ever you do mate, don't go looking at the engine - at the moment the most likely cause is electrical.
Also whatever you do don't take it to a bike shop to get ripped off, I be happy to travel to NA and fix it rather than u havingto give money away over a simple fault.
Posted: Dec 6th, '05, 21:53
by georgie_d
andrew wrote:a rectifier is a very easy part to test.
i would really appricaite you coming over what days and times are best with you, i work in the day but let us know i will get the kettle on :wink:
Posted: Dec 14th, '05, 20:52
by georgie_d
well andrew come up last night, arrived about 7 and left about 10.30 poor lad, he knows his stuff though tested everything and then we tried bump starting it, (killed me that did) and then pulled the bike to pieces and then hooray we think we found the problem(ok i say we :roll: andrew did everything and i held the lead light :oops: )the starter was shorting out :roll: so a 2nd hand one on the way :D andrew today, has been shopping around for me, the blokes a legend :!: :!:
and he says if i pick it up friday he is going to fit it for me :!: :!:
please be up standing for andrew
Big up andrew
yeah cheers mate
Posted: Dec 14th, '05, 23:12
by Jay
Great news Georgie mate, also WELLDONE for Andrew, TOP MAN 8)
Posted: Dec 15th, '05, 00:12
by 1blue
oh no.
that means the end of this thread. :roll: :twisted: :lol:
Posted: Dec 15th, '05, 00:18
by age
oh no it doesn't
Posted: Dec 15th, '05, 00:21
by svr-ash
AGE996 wrote:oh no it doesn't
Na its not one of ours blue :lol: :lol:
Posted: Dec 15th, '05, 09:34
by chris_1127
great news! good on Andy too - might be worth seeing if he will give the bike a clean and polish too whilst hes in an industrious mood ;)
Posted: Dec 15th, '05, 10:01
by andrew
OH SH1T the pressures on now, god i hope my fault diagnosis is correct or i'm going to look like a right tw4t.
Got to say its interesting working on a different bike but nerve racking when it don't belong to you. Couldn't believe how much of a pain it is to get the R6 carbs off (then again it would prob only be a two minute job if i had the long reach allen key thats required)
Chris as a triumph rider i'm only able to fix bikes cleaning them is alien to me afterall u can't polish a turd :-D
Posted: Dec 15th, '05, 11:02
by chris_1127
you cant polish a turd but you can wrap it up in plastic ;)
did it start OK when you tried bump-starting it then?
