clutch cable
akayel
clutch cable
Post by akayel »
Hi
My clutch cable is looking a bit dry (R1 2004). I'm guessing I need to disconnect it from the clutch lever in order to oil it properly?
If so whats the best way to disconnect it and lube it?
Many thanks!
Johnnyb
Re: clutch cable
Post by Johnnyb »
Dunno about disconnecting it but as for oiling it, i used to make a cone from masking tape and newspaper then squirt in a light oil but not wd40 and leave it hung up for a few hours and a light oil should work its way down until you get a drip or two out of the bottom (waiting for the comments on that one) you can work the cable a bit to help it through if your feeling energetic or alternatively buy a cable oiler like one of these:
http://www.gazbikes.co.uk/shop/tools-ca ... 3_134.html
