Sump funked?
Sump funked?
i decided i would change my oil today.. and also over-tighten my sump plug and leave my bike dripping oil :evil: I'm not sure whether i've shredded the thread on the sump.. or both.. but i'm ordering a new plug and washer.. i'll try the new washer without touching the sump first.. is there any non-permenant thread locking paste or anything i can use that will improve the seal and alos withstand the heat etc?
If i have dammaged the thread in the sump, would a helicoil insert do the job or would it just be easier to buy a whole new sump for it? Thanks, Tom.
Re: Sump funked
A new sump is an easy option if you can find one at a sensible price.
Common repair is a threadsert or helicoil. Either CMS in Pinhoe or Exeter Motor Services in the City Industrial Estate, Haven Banks will be able to sort you out. Don't take a chance and bodge it - the last thing you want is for it to give way and dump it's oil over the back tyre whilst out riding - potential crash and blown engine at the same time :wink:
jam
Re: Sump funked
Post by jam »
See what size thread the sump bolt is, then you can re tap the sump and use a larger bolt in it, for example if it's an M16 now then you should be able to re tap it to M18 and use a larger bolt in there, cheaper than having a Helicoil installed.
Personally I'm no fan of Helicoils, I always use Timeserts rather than Helicoil, I've had helicoils fail in the past, but I've only known a Timesert fail once and that was a very extreme example so doesn't really count.
Re: Sump funked
what about thread selant/locking stuff?
Cheese Monkey
Re: Sump funked
Post by Cheese Monkey »
Drill and tap, sorted the bandit right
Re: Sump funked
Cheese Monkey wrote:Drill and tap, sorted the bandit right
yeh i think that's what'l probly happen..
Re: Sump funked
In future..
haynes Manual
torque settings
Torque wrench
No problem
Re: Sump funked
Funky wrote:In future..
haynes Manual - check
torque settings - check
Torque wrench - nope
No problem
:cry:
Banditmax
Re: Sump funked?
Post by Banditmax »
To be fair tom the threads might have been screwed already. Unless you were using a 5ft bar to tighten it.
arkell
First Name: T
Re: Sump funked?
Post by arkell »
download the workshop manual off zxrworld.co.uk, print it off and keep a copy in the garage/shed. That'w what I've done and havnt fu*ked anything up 'yet'! :mrgreen:
[i]STOP CLUBBING[/i]
BABY SEALS!
Maver-Nick
Re: Sump funked?
Post by Maver-Nick »
You're not having much luck with this bike are ya mate... :roll: :(
webster
Re: Sump funked?
Post by webster »
Maver-Nick wrote:You're not having much luck with this bike are ya mate... :roll: :(
that's all part of the fun, adds to the satisfaction when it does work
Blimey
Re: Sump funked?
Post by Blimey »
I've done the same matey it comes with experience. Learn by your mistakes and all.
I ended up buying a second hand sump for £20 i think it was but you will also need a new gasket and then for even more practice you got all those little sump bolts to tighten to the correct torque :lol:
Good luck mate with what ever you consider doing but don't bodge it like Mossey suggested its not worth it
Re: Sump funked?
Banditmax wrote:To be fair tom the threads might have been screwed already. Unless you were using a 5ft bar to tighten it.
just used a 17mm halfords own ring spanner. i guess its just my almighty strength that's done it.. 8)
Banditmax
Re: Sump funked?
Post by Banditmax »
I guess that they were funked before you got to it anyway then, unless you put the bolt in cross threaded.
