the downpipes on the 400 were picked up as blowing in the mot the other day, i have got them off and cleaned them up and yes, they have rusted through.
i need the number of a good welder or someone who has a set for sale going cheap, please.
over to you.....
don't forget we are onX and Instagrambelieve it or not !!! southwestbikers@southwestbikers (original, I know.
KTM 1290 SDR KTM 690 supermoto smc R, Zx10r trackbike,
May not be worth patching them up, I guess other places will be close to rusting through too. Then again, how bad can they get sat in the garage lots of people make stainless steel replacements.
They have gone right up by the collar. 2 pipes, both will need patching quite alot.
Ss pipes are about £200 so won't be buying any of those.
Assuming welding doesnt cost much, it's probably worth patching it up, it isnt like it gets used massively especially in wet/salty conditions. Just make sure they get protected after its patched up.
You will have serious problems welding that lot, you can form the plates around the exsisting pipes but chances are its just going to burn through the metal you are trying to join it too. a couple of years ago we patched up my Bandit downpipes and from a small couple 10mm dia holes it turned into several hours of chasing ever expanding holes. Also plating around that part of the headers could cause clearance problems for your collars.
Think its onto breakers and flea bay for second hand pipes I'm afraid.
Thats just my opinion though
BIG thanks for miler, i took the pipes down to him, picked them up the next day - first class job.
thanks again Gary, kim owes you a coffee !
