Trying to find a Shoei GT-Air 2 Gloss Black XL in a shop near Taunton
Bob
First Name: Bob
Re: Trying to find a Shoei GT-Air 2 Gloss Black XL in a shop near Taunton
Post by Bob »
OK, for their faint-hearted here’s a trigger warning: post contains pictures of helmets…
I got my new helmet a week and a bit back, but have been quite busy.
Here’s what you get with a new Shoei helmet:
A lot of stuff:
service tool
Silicon oil
Pin lock EVO insert
Instruction book
Chin curtain
Breath guard
2x stickers
A pair of replacement pin lock pins
Another user manual
Also handy: the old and new main visors are cross compatible between the helmets - according to the guys at Helmet City.
And here are the side-by-side comparisons (old/new - left/right): Entry view
Retaining system changed from double D-ring to ratchet clip, some forward/rearward extension of the shell, areas to add on an intercom (Senna).
Rear view
A lot of venting changes - should be cooler to wear, but slighty more noisy (I use earplugs anyway)
Front view:
Note that the sun visor covers a greater area, and comes down a bit lower in the field of view. I’m a big fan of the inbuilt sun visor.
Frontal aspect:
The new helmet shell is a bit slimmer from side to side. The helmets weigh just about the same.
Cheers, Bob
Very very similar in style and design.
Looks fantastic through. If i recognise from the under side do i also see it has the quick release for the inside padding?
Also the sun visor drop downs are a god send. I have them on my x-lite and work so well
Bob
First Name: Bob
Post by Bob »
Yeah, the red tapes on the sides at approximately the cheek area release the front/face pads so that the helmet would be easier/safer to remove in event of an accident. I have to say that I haven’t tried an X-Lite, but only because I definitely have a Shoei-shaped head.
