Body Work Repair
Bilko1000
First Name: Darren
Body Work Repair
Post by Bilko1000 »
Hi, just to say I had a little topple and my fuel tank was dented as a result but the paint was undamaged.
Jason at Autodentz was able to remove all the dents without cracking the paint and provided your paint is good quality or original factory, he can offer this service to you too if needed.
I attach pics so you can see for yourself.
Jason at Autodentz can be contacted here and also fixes dents on cars etc too 07793 031 035 https://www.autodentz.co.uk/
I tried other bodywork repairers but they wanted to use filler and recommended a respray but other paintless dent removal providers wanted the tank off, fuel pump off and filler cap removed before they would touch it. Alot of them would not attempt a repair on a tank so I am amazed at the results, Jason will warn you though that if the paint comes off the tank it's your risk. Luckily Gixxer paint is high quality :)):
R1M 2020 Model / FIREBLADE 2019
Re: Body Work Repair
A good Repair
Bilko1000
First Name: Darren
Post by Bilko1000 »
:)): Ta
menzies3032
First Name: Robert
Post by menzies3032 »
Wow that's really impressive. have to keep that in mind thanks for sharing Darren
