can you spot the mistake?
So I get all sorts of bikes in all sorts of conditions come through my garage to be fettled with.
:-bd
Some in better states than others, some are pampered princesses and then there are the other ones....
I'm currently trying to make safe a bike and at each turn I'm running into a previous fettlers work.
Can you determine what I found here???
Hint, it's not the owl from Clash Of the Titans :)):
Robbo87
Re: can you spot the mistake?
Post by Robbo87 »
Caliper pistons in the wrong way around.
Is that from a 990 SMT?
If so then I suspect it's the way it should be.
There are no brake pads :-bd x_x
It's not the wrong way, it's just extra fluid capacity calipers.
Kata
First Name: John
Post by Kata »
No idea but the Owl reference is a good one. 😀
