cbr600rr track bike.
jimbo#9
Post by jimbo#9 »
can any one help??
i fitted a track body kit on today,
after much hastle getting the front wiring loom out to work the speedo..
the dam thing wont start now..
ive refitted the tilt sensor..(might be the problem)
any body experienced this??
any help much appreciated..
thanks.
jimbo. :cry:
http://www.myspace.com/hazard9
[img]http://www.hondaworld.ru/images/slogan1.gif[/img]
check youve reconnected the wiring loom to the back of the clocks properly and re check all other electrical connectors and make sure their connected and not trapped anywhere causing a short/bad earth.
i know it was a pain when i changed my 6rr over to track guise,their not the easiest of bikes to work on or modify are they ??
is the sidstand still fitted as it could be that switch
ps. where you going for a TD this time of year
jimbo#9
Post by jimbo#9 »
thanks deej,
no trackday this year..just prepin for next year.
been drilling holes etc. today..
ive got my bike on charge at mo. lmao.
it might be a flat battery.. :lol: , i think i had the ignition on for to long. not having the speedo on at the time.. no lights to warn..
fingers crossed...
yer it was a job to get the wiring loom free from around the lights..
how did you refit your tilt cutout swicth??
or did you bypass it??
Banditmax
Post by Banditmax »
If you do refit your cutout switch make sure you gum it up so that it doesn't actually work. Otherwise on the track you can have problems of cutting out when leaning hard into corners making you lose it.
my track kit had a sidestand cut out so i didnt need to worry about it. trouble with the wiring is that the japs have a lot smaller hands than we do so its easy for them and difficult for us huge handed peeps
